Technical Forum
iRule to forward to subsites
Walter_WorkAcct
Altostratus
Altostratus
In the following code, I want test1, test2 and test3 to route to the pool "pool_subsites_8443" and serve pages and all others to simply go to the main website. However, if you put in website/~test4 you simply get a 404. How can I have this go to the main website instead of return a 404?
when CLIENT_ACCEPTED {
    set hsl [HSL::open -publisher /Common/hsl_publisher]
    if { [HTTP::uri] starts_with "/~" } {
       HSL::send $hsl "The URI is [HTTP::uri] contains a tilde and will be sent to staff server."
       switch -glob [HTTP::uri] {
            "/~test1*" -
            "/~test2*" -
            "/~test3*"
                # URI ends with a specific username
                # All these cases use the same action.
         pool pool_subsites_8443
       default {
             pool pool_main_8443
        return
when CLIENT_CLOSED {
  unset hsl
2 REPLIES 2
Hi Walter_WorkAcct,
Can you try this iRule?
when CLIENT_ACCEPTED { set hsl [HSL::open -publisher /Common/hsl_publisher] }   when HTTP_REQUEST { set status 0 if { [HTTP::uri] starts_with "/~" } { set status 1 HSL::send $hsl "The URI is [HTTP::uri] contains a tilde and will be sent to staff server." switch -glob [HTTP::uri] { "/~test1*" - "/~test2*" - "/~test3*" { # URI ends with a specific username # All these cases use the same action. pool pool_subsites_8443 } default { pool pool_main_8443 } } } else { return } }   when HTTP_RESPONSE { if { $status && [HTTP::status] == 404 } { HTTP::redirect "https://example.com" } }   when CLIENT_CLOSED { unset hsl }
Initially I thought this fix was working correctly but there is a strange bug that if for example I am in example.com/~test1 and go to example.com/~test9 (test9 exists but is not in the select statement) it doesn't redirect and serves a page that I am not 100% sure where it is coming from. Still troubleshooting.
It is like it redirects to www.example.com but is serving the data with a subdirectory from this staff server.
