Technical Forum
iRule to block IP for period of time.
THE_BLUE
Cirrus
Cirrus
I need to create iRule to block client IP if it met below condition :
  • if client try to do attack ex: sql injection 3 times
then i want to block this IP for 1 hour and after 1 hour the IP should be unblocked .
is it possible to do this?
1 REPLY 1
Hello Blue.
You can react to a ASM violation using an iRule. Some examples:
https://support.f5.com/csp/article/K15573541
https://support.f5.com/csp/article/K37744422
After that you could include that IP into a table variable with one hour of timeout. This table would be checked everytime you receive a request. I did a similar iRule here:
https://devcentral.f5.com/s/articles/iRule-for-Brute-Force-Password-Guessing-Attacks?page=6
Regards,
Dario.
Regards,
Dario.
