Richard_Grigsb1's avatar
Richard_Grigsb1
Oct 06, 2022
iRule that checks client IP and send to a pool.
I have a case where a Mulesoft private IP address cannot use the FQDN and must use the IP address of the F5 LTM VIP as the host name.  I need to limit this access to only IP addresses for the Mulesoft subnet.   Here is what I have but is is not working at this time.  I can accespt the request is I remove the checking for client IP.
#DA7POLBACORE-TEST-iRule_CONE_Mulesoft_Non-Prod_VPC_Exclude_ver5
if { ([HTTP::host] equals "testwebsiteadminservice.tcbna.net") } {
if { [class match [IP::client_addr] equals Mulesoft_Non-Prod_VPC] } {
pool DA7POLBACORE-TEST-Pool-1135-OLB-CONE_8444
if { ([HTTP::host] equals "10.144.112.71") } {
reject
  • Try this:
        switch [HTTP::host] {
            "testwebsiteadminservice.tcbna.net" -
            "10.144.112.71" {
            default {
                reject
    Also, if the source addresses are in a single contiguous subnet, you could actually just define this subnet in the Source Address field of the VIP.
  • Sajid's avatar
    Sajid
    an effortless way to achieve your requirement.
    Data Group List defined under irule >
    if { ( [class match [IP::client_addr] equals access_list]) } {
    pool node_test1_pool
    pool node_test2_pool
