Technical Forum
irule: redirect to different paths with same host.
franktruong3
I'm new at F5 and iRule.
I try to redirect from root location to different path on the same node.
https://abc.domain.com -> https://abc.domain.com/path
What is wrong with this rule?
=================iRule===================================================
  if { ([string tolower [HTTP::host]] eq "abc.domain.com") } {
       HTTP::redirect "https://abc.domain.com/path"
2 REPLIES 2
SanjayP
MVP
MVP
 if { ([string tolower [HTTP::host]] eq "abc.domain.com") and ([HTTP::uri] eq "/")} {
It works….Thanks SanjayP!!!
