Technical Forum
Custom Alert Banner
iRule Path Routing to pool review.
viziony
Cirrus
Cirrus
Hello I have a few designated paths in which I would like to direct to a specific pool otherwise to a default pool. Here is the script that I have came up with using a combination of others I have found on the site. Can you help me confirm this is correct and will work? This is also for HTTPS, so do I need to change "when HTTP_REQUEST" to "when HTTPS_REQUEST"?
if { [string tolower [HTTP::uri]] equals "/a.php" or [string tolower [HTTP::uri]] starts_with "/b.php"} or [string tolower [HTTP::uri]] starts_with "/c/*"} { pool /Common/pool-A_pool } else { pool Common/pool-B_apool }
Thanks for your time.
3 REPLIES 3
Hi @viziony
I think you could use a switch statement rather than a lot of or conditions. This iRule should work for you.
Instead of starts_with, I use a wildcard *.  You could also use HTTP::path instead of HTTP::uri.
    switch -glob -- [string tolower [HTTP::uri]] {
        "/a.php*" -
        "/b.php*" -
        "/c.php*" {
            pool my_pool_ABC
        default {
            pool my_pool_XYZ
Let me know if this one works for you, or it needs adjustments.
KR
Daniel
Thank you Dan for the quick reply! Will update this thread once I test it out.
vaibhav
Yep switch -glob is best option for you and for more details on the various options/functions available to switch pool you can refer below documentation it is a good read
https://community.f5.com/t5/technical-articles/irules-101-05-selecting-pools-pool-members-and-nodes/...
