iRule insert IP::remote_addr to uri redirect
155
In our scenario, we have public-facing URL https://domain.com. I need to receive traffic from that url and forward it to one of the pool nodes as below:
https://subdomain.[IP::remote_addr].com:9000. I understand how to do basic http redirect but I can't figure out how to concat/insert pool member's ip address into the redirect uri.
2 REPLIES 2
youssef1
Cumulonimbus
Cumulonimbus
Hello,
For your need you have to set your hostname in LB_SELECTED event when the backend server will be selected:
when LB_SELECTED { HTTP::header replace Host "subdomain.[LB::server addr].com" log local0. "serverIP $serverIP" log local0. "Host: [HTTP::header value Host]" }
So you don't need to insert the port, this one will be redirect automaticly (by default in your VS the Port Translation is checked).
kee p me in touch if you need more details.
regards.
155
  Thanks for the reply! I didn't know about LB_SELECTED. So, I did what you suggested but when I navigate to https://domain.com and seems to just pass the traffic alone to one of pool members without doing redirect to https://subdomain.[IP::remote_addr].com.
Do I need to include and other options in that iRule like HTTP redirect?
