15-Dec-2020 06:43
Hello Team,
I'm in need of an Irule to block HTTP request if the HTTP Referer header value is null or with wrong domain address.
Could you please help with an irule for this request?
set referer [string tolower [HTTP::header value "Referer"]]
if {($referer != "") && !($referer starts_with "*.abc.com")} {
log local0.info "Rejecting request to [HTTP::uri] with Referer $referer"
reject
I have also tried the below irule and this also not worked.
Class allowed_referers {
*.abc.com
if { ( [matchclass [HTTP::header value "Referer"] $referer contains allowed_referers ] ) }
allow
Regards,
Thiyagu
15-Dec-2020 11:19
Hi Thiyagu,
* character is not wildcard in here.
Can you try that?
if {($referer ne "") && !($referer contains ".abc.com")}
16-Dec-2020 23:14
Hello aaa,
I have tried the below irule and it is not working. As far I know the the flow logic is correct and for some reason this irule is not working.
Could you please correct me if I' missing something here?
when HTTP_REQUEST
HTTP::respond 400 content "Bad Request" "Content-Type" "text/html"
Regards,
Thiyagu
17-Dec-2020 04:14
Hi Tiyagu,
Can you test this and investigate logs?
log local0. "referer status: [HTTP::header exists Referer] | clientip: [IP::client_addr] | uri: [HTTP::uri]"
if { [HTTP::header exists "Referer"] and not ([HTTP::header value "Referer"] contains ".abc.com") } {
log local0. "referer header found | uri: [HTTP::uri]"
HTTP::respond 400 content "Bad Request" Content-Type "text/html"
17-Dec-2020 06:19
Thanks a lot eaa.
As a plan B I have also worked on the below iRULE. Could you please correct me if I' missing something ?
switch -glob [HTTP::header "Referer"] {
"*.abc.com/*" {
# Allow Request to go through...
default {
Thanks a lot in advance
Regards,
Thiyagu
