Technical Forum
Irule for logging Allowed Response status code
man
hi everyone
I have configured a policy that 500 code is not in the Allowed Response status code list on Policy Properties tab. But when i use asm events in i rule it doesnt log anything:
when ASM_RESPONSE_VIOLATION {
   log local0. "[ASM::violation_data]. unblocked for [IP::client_addr]"
I tested this events but nothing is logged and events doesnt trigger.
ASM_REQUEST_BLOCKING
ASM_REQUEST_DONE
ASM_REQUEST_VIOLATION
IN_DOSL7_ATTACK
1 ACCEPTED SOLUTION
Did you enable Trigger ASM iRule Events on your ASM policy??
Cheers,
Kees
2 REPLIES 2
Cheers,
Kees
man
I enabled it and it works fine now. thank you for your response Kees
