Technical Forum
iRule for limiting concurrent sessions to VS
Mohanad
Hello everyone,
i'm looking for iRule for limiting concurrent sessions.
when the sessions has reached the maximum (10,000), new sessions will be droped if the mobile app trying to connect to this uri (/v1/healthCheck), i found 2 iRules, but i want to combine them to achieve the required actions
as far i understand the below irule working on layer4
when CLIENT_ACCEPTED {
    set tbl "connlimit:[IP::client_addr]"
    set key "[TCP::client_port]"
    if { [table keys -subtable $tbl -count] > 1000 } {
        event CLIENT_CLOSED disable
        reject
        table set -subtable $tbl $key "ignored" 180
        set timer [after 60000 -periodic { table lookup -subtable $tbl $key }]
when CLIENT_CLOSED {
    after cancel $timer
    table delete -subtable $tbl $key
and this one on layer 7
    if {[HTTP::uri] contains "/v1/healthCheck"} {
            HTTP::respond 404 content "Maximum concurrent sessions limit reached"
            drop
 Thank you.
1 REPLY 1
Paulius
MVP
MVP
@Mohanad I believe you could do the following but this hasn't been tested so proceed with caution before configuring this in production.
when CLIENT_ACCEPTED priority 500 {
when HTTP_REQUEST priority 500 {
    if { [table keys -subtable ${tbl} -count] > 1000 } {
            drop
            reject
        table set -subtable ${tbl} ${key} "ignored" 180
        set timer [after 60000 -periodic { table lookup -subtable ${tbl} ${key} }]
when CLIENT_CLOSED priority 500 {
    after cancel ${timer}
    table delete -subtable ${tbl} ${key}
Do you have any particular reason you couldn't use the connection limit of the pool member or total pool members connections and then generate a response based on those pool members being in a "down" state when the connection limit is reached? It seems like this unnecessarily overcomplicates your configuration and makes it a bit more difficult to support in the future.
