14-Mar-2023 08:43
Hello,
I want to send the F5 Syslog, especially the one on ltm to a remote server in my case to fluentd.
Where I can find the rule or example to forward to? I don't know the steps since I didn't do them before.
Solved! Go to Solution.
14-Mar-2023 12:29
14-Mar-2023 12:29
14-Mar-2023 16:18
Thanks, much for your response, so I am looking remote system but the syslog pushes to fluent. I heard that needs to be done on
1 - on the declaration (I know that part)
2 -from iRule need to be configured also which I don't know. I wish I can find similar steps what I can do.
Thanks!!!
