cwdusheke's avatar
cwdusheke
Jan 23, 2020
Solved
irule - converting if to switch
I am trying to convert my irule from using the if to the switch. Here' s an email of my old irule.
if { (([HTTP::host] contains "abc1.com") && ([HTTP::uri] == "/" )) }{
HTTP::uri "/tf/myPLAN/SponsorWelcome?cz=123456789"
elseif { (([HTTP::host] contains "abc2.com") && ([HTTP::uri] == "/" )) }{
HTTP::uri "/tf/myPLAN/SponsorWelcome?cz=223456789"
elseif { [string tolower [HTTP::host]] eq "example1.com" } {
    HTTP::respond 301 Location "https://example11.com"
elseif { [string tolower [HTTP::host]] eq "example2.com" } {
    HTTP::respond 301 Location "https://example22.com"
  • Hello.
    Try this:
    	switch -glob [string tolower [HTTP::host]] {
    		"*abc1.com" {
    			if { [HTTP::uri] eq "/" } {
    		"*abc2.com" {
    		"*example1.com" {
    		"*example2.com" {
    KR,
    Dario.
  • Hello.
    Try this:
    		"*abc1.com" {
    		"*abc2.com" {
    		"*example1.com" {
    		"*example2.com" {
    KR,
    Dario.
  • Thank you very much. I was looking through a lot of examples but not sure how to do it.
    • Dario_Garrido's avatar
      Dario_Garrido
      Icon for Noctilucent rankNoctilucent
      You're welcome :-)
      Please, don't forget to mark the answer as "the best" if it was helpful.
