Livius's avatar
Livius
Icon for Cirrus rankCirrus
6 years ago
Interface counters via iControl
We are in process of building analytics graphs, by collecting equipment counters via iControl (REST API). We managed to fetch the pool, node, member, VS counters and stats but we could not find a way to find the following metrics : - total connections - TPS/SSL counters - interface counters
We could not find the right objects to be queried via iControl for these graphs. Can someone point me in the right direction ?
Thanks in advance!
  • I think it should be something below,
    curl -s -k -u admin -H "Content-Type: application/json" -X GET https://1.1.1.1/mgmt/tm/net/interface/stats | jq
    Output would be,
    Enter host password for user 'admin':
      "kind": "tm:net:interface:interfacecollectionstats",
      "selfLink": "https://localhost/mgmt/tm/net/interface/stats?ver=13.1.0.5",
      "entries": {
        "https://localhost/mgmt/tm/net/interface/1.1/stats": {
          "nestedStats": {
            "kind": "tm:net:interface:interfacestats",
            "selfLink": "https://localhost/mgmt/tm/net/interface/1.1/stats?ver=13.1.0.5",
            "entries": {
              "counters.bitsIn": {
                "value": 0
              "counters.bitsOut": {
                "value": 0
              "counters.dropsAll": {
                "value": 0
              "counters.errorsAll": {
                "value": 0
              "counters.pktsIn": {
                "value": 0
              "counters.pktsOut": {
                "value": 0
              "mediaActive": {
                "description": "none"
              "tmName": {
                "description": "1.1"
              "status": {
                "description": "disabled"
  • Chikita_84258's avatar
    Chikita_84258
    Historic F5 Account
    Total connections
    curl -sku admin https://localhost/mgmt/tm/sys/connection
    TPS/SSL counters
    curl -sku admin https://localhost/mgmt/tm/sys/performance/throughput
    Interface counters
    Possibly you might be looking for the output from 'tmsh show sys traffic'. If that's the case,
    curl -sku admin https://localhost/mgmt/tm/sys/traffic/stats?options=raw
    If that's 'tmsh show sys tmm-traffic', then
    curl -sku admin https://localhost/mgmt/tm/sys/tmm-traffic
