Carp3Di3m's avatar
Carp3Di3m
Nov 09, 2007
Installation of Hotfixes
Does it matter in which order the hotfixes have been installed?
Is that an issue when you have master with slaves?
Could this cause some trouble, like not replicating admin password changes to all the boxes?
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Yes, you should install them in order.
    I suppose that it could affect sync functionality if both boxes were hotfixed in a different sequence.
    I believe that all hotfixes are supposed to include rollups of previous sets, so you should just be able to install the latest one.
    HTH
    /deb
