INOPERATIVE state when upgrading from 11.6.0.0.0.401 to 12.0.0.0.606
Hi F5 Team,
I am working with a VM VE LAB license which is working nice but when I try to upgrade from 11.6.0.0.0.401 to 12.0.0.0.606 state becomes INOPERATIVE. I mention that this virtual machine emerges with the BIGIP-11.4.1.608.0-scsi.ova downloadable from F5 Site I installed version 12 with 'tmsh install sys software image create-volume BIGIP-12.0.0.0.606.iso volume HD1.5' from versión 11.6 (which is Ok), after that I do 'reboot volume HD1.5', then it starts up on version 12 and when I enter CLI mode it only prompts: [root@VALV:INOPERATIVE:Standalone] config
What I did was
[root@VALV:INOPERATIVE:Standalone] config load sys config
It starts up, but state doesn't become 'Active'
I follow this also: https://devcentral.f5.com/questions/stuck-in-configuration-utility-restarting
I have faced the same issue while I was upgrading the F5 LTM 2000Series.
And I followed the following steps and it's work.
01- access via ssh and login with root ID
02- go to tmsh
03- stop sys service all
04- start sys service all
05- load sys ucs Base_Config.ucs no-license
*** after that prompts: root@(VALV)(cfg-sync Standalone)(INOPERATIVE)(/Common)(tmos) load sys ucs Base_Config.ucs no-license The connection to mcpd has been lost, try again. root@(VALV)(cfg-sync Standalone)(INOPERATIVE)(/Common)(tmos) load sys ucs Base_Config.ucs no-license Data Input Error: The file, /var/local/ucs/Base_Config.ucs, can't be found. Be aware, UCS filename should have a suffix, .ucs.
///Can't do this 06- save sys config
07- reboot ////
This is the log:
[root@VALV:INOPERATIVE:Standalone] config tail -50 /var/log/ltm
Dec 18 14:19:46 VALV info mprov:23198:: '/bin/mount -t hugetlbfs none /dev/mprov/tmm 2>&1 1>/dev/null'
Dec 18 14:19:46 VALV info mprov:23198:: '/bin/mknod /dev/mprov/tmm/physmem c 252 1 2>&1 1>/dev/null'
Dec 18 14:19:46 VALV info mprov:23198:: '/usr/bin/bigstart start increase_entropy tmipsecd tmm'
Dec 18 14:19:46 VALV notice logger: /usr/bin/perl /usr/bin/mprov.pl --quiet --commit tmos ==> /usr/bin/bigstart start increase_entropy tmipsecd tmm
Dec 18 14:19:48 VALV info mprov:23198:: '/usr/bin/bigstart start'
Dec 18 14:19:48 VALV notice logger: /usr/bin/perl /usr/bin/mprov.pl --quiet --commit tmos ==> /usr/bin/bigstart start
Dec 18 14:19:51 VALV info mprov:23198:: 'fyi: mcpd is up'
Dec 18 14:19:51 VALV info mprov:23198:: 'Setting F5::COAPI::DbVariable{provision.action} = none'
Dec 18 14:19:51 VALV info mprov:23198:: 'Provisioning successful.'
Dec 18 14:19:52 VALV notice mcpd[19986]: 01070404:5: Add a new Publication for publisherID %istatsd and filterType (nil)
Dec 18 14:19:53 VALV notice scriptd[20336]: 014f0001:5: started
Dec 18 14:19:53 VALV notice mcpd[19986]: 01070404:5: Add a new Publication for publisherID scriptd-publisher and filterType (nil)
Dec 18 14:19:53 VALV notice iprepd[19882]: 015c0009:5: IP Reputation has no license currently
Dec 18 14:19:56 VALV notice mcpd[19986]: 01070413:5: Updated existing subscriber statsd with new filter class 0.
Dec 18 14:19:56 VALV notice mcpd[19986]: 01070404:5: Add a new Publication for publisherID statsd and filterType 0x8000000
Dec 18 14:19:58 VALV notice sod[20456]: 010c0044:5: Command: running disable zrd bigstart.
Dec 18 14:20:00 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart singlestatus avrd
Dec 18 14:20:00 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart singlestatus dosl7d
Dec 18 14:20:00 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart singlestatus asm
Dec 18 14:20:00 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart restart asm
Dec 18 14:20:02 VALV notice zxfrd[20886]: 01530007:5: /usr/bin/zxfrd started ===============================
Dec 18 14:20:02 VALV notice mcpd[19986]: 01070404:5: Add a new Publication for publisherID ZXFRD_Publisher and filterType 0x400
Dec 18 14:20:02 VALV notice zxfrd[20886]: 01531300:5: Cluster status changing from Unknown to Standalone.
Dec 18 14:20:05 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart singlestatus datasyncd
Dec 18 14:20:05 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart singlestatus admd
Dec 18 14:20:05 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart singlestatus mgmt_acld
Dec 18 14:20:05 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart singlestatus dwbld
Dec 18 14:20:05 VALV notice logger: /bin/sh /etc/bigstart/scripts/avr.provision ==> /usr/bin/bigstart restart dwbld
Dec 18 14:20:43 VALV notice sod[20456]: 01140030:5: HA proc_running tmm is now responding.
Dec 18 14:20:43 VALV notice sod[20456]: 010c006d:5: Leaving Offline for Active for dbvar not redundant.
Dec 18 14:20:43 VALV notice sod[20456]: 010c0053:5: Active for traffic group /Common/traffic-group-1.
Dec 18 14:20:43 VALV notice sod[20456]: 010c0019:5: Active
Dec 18 14:18:24 VALV notice tmm[14920]: 01010019:5: Caught signal 15, exiting
Dec 18 14:20:39 VALV notice tmm[28604]: 01010001:5: pgo_use x86_64 vadc TMM Version 12.0.0.0.0.606 starting
Dec 18 14:20:44 VALV notice mcpd[19986]: 01070404:5: Add a new Publication for publisherID TMM and filterType (nil)
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: 6RD feature is licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: PSM feature is licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: AFM feature is licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: PEM feature is not licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: Gy feature is not licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: Gx feature is not licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: MAP feature is licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: CGNAT feature is licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: Qosmos IXE Engine feature is not licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: FEC feature is licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: CEC feature is licensed
Dec 18 14:20:50 VALV notice tmm[28604]: 01010044:5: AFM feature not licensed
Dec 18 14:20:51 VALV notice sod[20456]: 01140044:5: HA reports tmm ready.
Dec 18 14:20:50 VALV notice tmm[28604]: 01340011:5: HA unit 1 state change: from 0 to 1.
Dec 18 14:20:51 VALV notice sod[20456]: 010c0049:5: Tmm ready - links up.
.....without response... :(
On another attempt I try to reactivate license manually but doesn't work either
Have you ever deal with some kind of this? Trying to upgrade from some version 11.6 to 12?
Should I revoke license?
Also I can notice that I cannot logout from GUI if I log in (on version 12).
Thanks a lot!
