Pranav1's avatar
Pranav1
Mar 15, 2020
Incomplete HWaddress in Dynamic ARP of BIGIP F5
Hi all,
I setup a F5 on VMware and i configured below settings:
  1. Management IP : 10.208.107.8/26 with Default Gateway : 10.208.107.1
  2. created Vlan 606 and Tag it with interface 1.1 and i cross checked the MAC address of VM network adapter with F5 interface (Both matched).
  3. created self IP and assigned Vlan 606 to it with IP 10.208.108.5/26.
  4. Routes: Destination 0/0 and Gateway: 10.208.108.2
  5. Added one server in (Local traffic -> Nodes) which is showing down (IP: 10.208.108.9) (Monitoring ICMP)
Note: whenever i remove Self-IP, the server comes UP.
The problem is i am unable to get ARP of Self-IP on my FW.
Unable to ping 10.208.108.9 Node from F5
Network - ARP - Dynamic ARP --- Here it is showing me 10.208.108.9 & 10.208.108.2 but in MAC address section it is showing "incomplete"
As i am not getting ARP, Self-IP and Nodes are not able to communicate.
What i suspect is the Media Speed of F5 interface is 10000 , auto
Interface configured on FW with vlan 606 has BW 1000 Mbps.
I tried to change F5 interface media speed to 1000 by using "modify net interface 1.1 media 1000T-FD", it given an error:
"invalid property vlaue "media":"1000T-FD" The requested media is invalid, valid settings are: 10000T-FD, auto. please see SOL14556 for details.
Question:
  1. Is the Mismatch of media speed is causing the ARP issue ?
  2. Have i missed some configuration which is causing this ?
Please suggest a solution as i need to get this resolved asap.
I can also show my settings on a ZOOM session, if someone is willing to help.
Thanks in Advance.
  • Is 10.208.108.2 your SVI or L3 as you are using it as gateway? Is it actually .2 or it is .1?
    please cross check same.
    Mayur
  • Sorry, it was a typo mistake, actually i configured 10208.108.1 as a gateway.
    fw01# sh ip
    System IP Addresses:
    Interface        Name          IP address   Subnet mask   Method
    Ethernet0/0       outside        XXX.XXX.XXX.XX 255.255.255.240 CONFIG
    Ethernet0/1.601     inside-01       10.208.107.1  255.255.255.192 manual
    Ethernet0/1.604     inside-604       10.208.107.129 255.255.255.192 manual
    Ethernet0/1.605     inside-605       10.208.107.193 255.255.255.192 manual
    Ethernet0/1.606     inside-606       10.208.108.1  255.255.255.192 manual
    Have you check if Packet Filters is disable on you F5 BIG-IP device ? (Network -> Packets filters) or are you using AFM module ?
    Regards
  • ebeng's avatar
    ebeng
    did you resolve it? I'm having exactly the same issue.
    When the SELF_IP of the F5 is in the SAME VLAN as the servers, it does not respond to anything. (even when the DG is the FW-interface in that VLAN)
    ofcourse when you delete the SELF_IP the traffic is now flowing through the mgmnt. (this should be even not possible from security-perspective)
