Sort By
- Jad_Tabbara__J1Cirrostratus
Hello Saud,
I guess you are using VE BIG IP because usually this alarm occurs when your system has exceed the max allowed throughput rate subscribed in your license.
To display this rate using advanced shell command line, type the following command:
grep "perf_VE_throughput_Mbps" /config/bigip.license
Source : https://support.f5.com/csp/article/K14356
It is a critical alarm, because when the threshold is reached, the system will start dropping connections...
You can use following command to list the number of ingress/egress packets that have been dropped by each TMM :
tmctl -d blade tmm/if_shaper
Source: https://support.f5.com/csp/article/K15831
If that was the issue then you will need to upgrade your license...
Regards
