How much bandwidth are we using?
How to determine how much bandwidth your BIG-IP is actually using?
Future licensing has a 200Mbps licensing limitation divided across TMM's (K15831) and we need to know if the current usage is greater than this. We are running BIGIP version 12.1.2. Should we use AVR? SNMP? Bandwith Management?
According to the output on my device I am running one TMM instance with two threads (APM minimal provisioning)
From K14340 i've run the following commands...
config ps T | grep tmm | grep T 20023 ? SLl 723:28 tmm.0 -T 2 --tmid 0 --npus 2 --platform Z100 -m -s 6234 config tmsh show sys tmm-info | grep Sys::TMM Sys::TMM: 0.0 Sys::TMM: 0.1
Published Aug 30, 2022
1 Comment
