Technical Forum
images is not loading correctly
Jaspreetgurm
Altocumulus
Altocumulus
Images is not loading the page sitting behind F5 LTM
see error below.
Virtual server is setup with 2 pool memebers.
SSL offloading profile is setup on LTM
below irule also configured.
 if { [string tolower [HTTP::uri]] starts_with "/gamification" } {
  HTTP::uri [string map -nocase {"/gamification" ""} [HTTP::uri]]
can someone help on this.
7 REPLIES 7
crodriguez
Legacy Employee
Legacy Employee
Can you share the request and response headers on the request that fails so we have a little more to information for troubleshooting, please?
I have attached both screenshot below.
xuwen
MVP
MVP
string map will replace all the string if it contains "/gamification", you need use regsub to replace first /gamification:
11 % set uri "/gamification/gamification_uploads/header.jpg"
(bin) 12 % string map -nocase {"/gamification" ""} $uri
_uploads/header.jpg
(bin) 13 % set uri
(bin) 14 % regsub -nocase "/gamification" $uri "" new_uri
1
(bin) 15 % set new_uri
didn't worked... can you please explain more
You can simply tweak this part, so it matches your requirement.
HTTP::uri [string map -nocase {"/gamification/" "/"} [HTTP::uri]]
Explanation:
set newuri [string map -nocase {"/gamification" ""} $uri]
Will give you "_uploads/header.jpg"
But being specific like below,
set newuri [string map -nocase {"/gamification/" "/"} $uri]
Will give you "/gamification_uploads/header.jpg"
Hope it explains.
can you please brief more on this?
I tried the above suggestion and I got blank page.
