Technical Forum
Custom Alert Banner
if-index differences
mlwebster
Cirrus
Cirrus
Can someone please help?
Should the configuration of both halves of a F5 HA cluster have the same if-index value when I look at the running configuration?
Some network statements (see below) are identical on both halves, others have a differing if-index values
net vlan VLAN888 {
  if-index 960
  interfaces {
    Core_Net {
      tag-mode service
      tagged
  tag 888
Is this an issue for the networks where there is a difference?
2 REPLIES 2
Simon_Blakely
F5 Employee
F5 Employee
net config elements are part of base config, and are specific to the device - they are not synced. These elements need to match functionally between the members of a device group.
if-index is administrative, not functional, so there is no requirement to match. It just reflects that the elements were created in a different order between the members, and data can be accessed via different if-indexes using SNMP.
mlwebster
Cirrus
Cirrus
Thanks Simon - much appreciated
