Technical Forum
Custom Alert Banner
Identify which virtual servers are using a specific SSL certificate
Chris_Olson_172
We use a wildcard SSL certificate for our QA sites. There are many of them. I am renewing the SSL cert but have no idea which Virtuals are using it. Is there an easy way to determine this other than checking each and every virtual, listing the Client-ssl profile and then looking up the profile to see what certificate is being used?
3 REPLIES 3
Jay_Spell
I would use cli for this.
tmsh list ltm profile client-ssl | grep -B 13 -i cert-name.crt
This should give you all the profiles associated with the certificate. Then you can search the virtual servers for any with the associate profiles.
tmsh list ltm virtual | grep -B 12 profile_name
AMiles_377865
Cirrocumulus
Cirrocumulus
Hello Chris,
This will give you a list of all virtual servers, and if it has your specific client-ssl-profile, it will be right below it.
tmsh list ltm virtual | grep -E 'virtual|'
That keeps you from checking each one individually in the GUI, and knowing which servers can expect the change.
To check which client-ssl profiles are using which certificates, run
tmsh list ltm profile client-ssl cert
Best of luck,
Austin
hareshthummar1
I have similar kind of problem. i have multiple partition created on vcmp and it is very difficult to look which virtual server associated to which ssl certificate and respective exapariy date. do we have any easy mathod to check it
