I am planning to upgrade BIG IP LTM from 12.1.3.4 Build 0.0.2 to 13.1.3.4
Can i Direct upgrade from v12.1.3.4 build 0.0.2 version to 13.1.3.4 build 5 or should i Upgrade to 13.1.3 after need to upgrade 13.1.3.4
can someone please confirm and share the link
I don't think any specific link will be available. Upgrade process is same in F5 Module.
This is right set of software BIGIP-13.1.3.4-0.0.5.iso
Hope it will help you.
- JustCooLpOOLe
Cirrocumulus
I was able to upgrade our BIG-IP DNS from 12.1.2.4 to 13.1.3.4 due to CVE-2020-5902 and everything has seemed to be fine.
- kishore
Is it Direct Upgrade from 12.1.2.4 to 13.1.3.4 or have you upgrade do i need to upgrade first to Base version of 13.x
- JustCooLpOOLe
Cirrocumulus
Yep. I relicensed the device...uploaded and installed 13.1.3.4 iso from downloads.f5.com and booted into the new boot location. Just one upgrade...no installing 13.0 and then 13.1.3.4...just straight to 13.1.3.4.
These devices are 2000s and we followed the normal upgrade process.
