LyonsG_85618's avatar
LyonsG_85618
Feb 06, 2015
HTTPS Monitor not working as expected
I have created an HTTPS monitor as follows:
       GET /idauth/isAlive.jsp\r\n
The receive string is set as:
    ALIVE
There are 2 servers and when i curl them i get the following:
First Server
    curl -k https://server1.domain.com:8443/idauth/isAlive.jsp
        OpenAM
    Server is DOWN
Second server:
    curl -k https://server2.domain.com:8443/idauth/isAlive.jsp
      OpenAM
    Server is ALIVE:
However. Both servers are being flagged as unavailable.
If I change the receive string to DOWN - both servers are flagged as available.
I have changed curl to verbose to check for separate words showing ALIVE/DOWN but this doesnt show anything:
     curl -k -v https://server2.domain.com:8443/idauth/isAlive.jsp
    * About to connect() to server2.domain.com port 8443 (0)
    *   Trying 172.31.151.143... connected
    * Connected to server2.domain.com (172.31.151.143) port 8443 (0)
    * successfully set certificate verify locations:
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
     CApath: none
    * SSLv3, TLS handshake, Client hello (1):
    * SSLv3, TLS handshake, Server hello (2):
    * SSLv3, TLS handshake, CERT (11):
    * SSLv3, TLS handshake, Server finished (14):
    * SSLv3, TLS handshake, Client key exchange (16):
    * SSLv3, TLS change cipher, Client hello (1):
    * SSLv3, TLS handshake, Finished (20):
    * SSL connection using AES128-SHA
    * Server certificate:
    *        subject: C=GB; ST=Scotland; O=STANDARD LIFE; OU=IS; CN=server2.domain.com
    *        start date: 2014-11-11 21:48:09 GMT
    *        expire date: 2028-07-20 21:48:09 GMT
    *        common name: server2.domain.com (matched)
    *        SSL certificate verify result: self signed certificate in certificate chain (19), continuing anyway.
    GET /idauth/isAlive.jsp HTTP/1.1
    User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/0.9.8y zlib/1.2.3 libidn/0.6.5
    Host: server2.domain.com:8443
    Accept: */*
    HTTP/1.1 200 OK
    Cache-Control: private
    Expires: Thu, 01 Jan 1970 01:00:00 GMT
    Set-Cookie: JSESSIONID=A847EA20D06FC26A9B944B9CB5CC397E; Path=/idauth/; Secure; HttpOnly
    Content-Type: text/html;charset=ISO-8859-1
    Content-Length: 115
    Date: Fri, 06 Feb 2015 13:17:35 GMT
    Server: Anonymous
    html>
    head>
        OpenAM
    /head>
    body>
    h1>Server is ALIVE:
    * Connection 0 to host server2.domain.com left intact
    * Closing connection 0
    * SSLv3, TLS alert, Client hello (1):
Has anyone seen anything like this?
