LyonsG_85618's avatar
LyonsG_85618
Feb 06, 2015
HTTPS Monitor not working as expected
I have created an HTTPS monitor as follows:
       GET /idauth/isAlive.jsp\r\n
The receive string is set as:
    ALIVE
There are 2 servers and when i curl them i get the following:
First Server
    curl -k https://server1.domain.com:8443/idauth/isAlive.jsp
        OpenAM
    Server is DOWN
Second server:
    curl -k https://server2.domain.com:8443/idauth/isAlive.jsp
      OpenAM
    Server is ALIVE:
However. Both servers are being flagged as unavailable.
If I change the receive string to DOWN - both servers are flagged as available.
I have changed curl to verbose to check for separate words showing ALIVE/DOWN but this doesnt show anything:
     curl -k -v https://server2.domain.com:8443/idauth/isAlive.jsp
    * About to connect() to server2.domain.com port 8443 (0)
    *   Trying 172.31.151.143... connected
    * Connected to server2.domain.com (172.31.151.143) port 8443 (0)
    * successfully set certificate verify locations:
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
     CApath: none
    * SSLv3, TLS handshake, Client hello (1):
    * SSLv3, TLS handshake, Server hello (2):
    * SSLv3, TLS handshake, CERT (11):
    * SSLv3, TLS handshake, Server finished (14):
    * SSLv3, TLS handshake, Client key exchange (16):
    * SSLv3, TLS change cipher, Client hello (1):
    * SSLv3, TLS handshake, Finished (20):
    * SSL connection using AES128-SHA
    * Server certificate:
    *        subject: C=GB; ST=Scotland; O=STANDARD LIFE; OU=IS; CN=server2.domain.com
    *        start date: 2014-11-11 21:48:09 GMT
    *        expire date: 2028-07-20 21:48:09 GMT
    *        common name: server2.domain.com (matched)
    *        SSL certificate verify result: self signed certificate in certificate chain (19), continuing anyway.
    GET /idauth/isAlive.jsp HTTP/1.1
    User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/0.9.8y zlib/1.2.3 libidn/0.6.5
    Host: server2.domain.com:8443
    Accept: */*
    HTTP/1.1 200 OK
    Cache-Control: private
    Expires: Thu, 01 Jan 1970 01:00:00 GMT
    Set-Cookie: JSESSIONID=A847EA20D06FC26A9B944B9CB5CC397E; Path=/idauth/; Secure; HttpOnly
    Content-Type: text/html;charset=ISO-8859-1
    Content-Length: 115
    Date: Fri, 06 Feb 2015 13:17:35 GMT
    Server: Anonymous
    html>
    head>
        OpenAM
    /head>
    body>
    h1>Server is ALIVE:
    * Connection 0 to host server2.domain.com left intact
    * Closing connection 0
    * SSLv3, TLS alert, Client hello (1):
Has anyone seen anything like this?
  • shaggy's avatar
    shaggy
    this is definitely a strange issue. i don't see anything wrong in your configuration so far. next steps are definitely a packet trace and a support case (if you haven't opened one yet).
    can you also post the pool configuration (tmsh list ltm pool (pool-name))?
    • LyonsG_85618's avatar
      LyonsG_85618
      list ltm pool POOL_SYST_IDAUTH_INTERNAL_LIVE_HTTPS ltm pool POOL_SYST_IDAUTH_INTERNAL_LIVE_HTTPS { load-balancing-mode predictive-member members { slglvmfi:pcsync-https { address 172.31.251.141 session monitor-enabled state up } slglvmfk:pcsync-https { address 172.31.151.143 session monitor-enabled state up } } monitor MONITOR_SYST_IDAUTH_INTERNAL_LIVE_HTTPS partition FEDERATION }
  • this is definitely a strange issue. i don't see anything wrong in your configuration so far. next steps are definitely a packet trace and a support case (if you haven't opened one yet).
      LyonsG_85618
  • This issue was eventually discovered as an application problem.
    BIG-IP was, as always, not the problem.
    • Jeff_M_44528's avatar
      Jeff_M_44528
      I observed similar symptoms as well. Would you mind sharing more about the "application problem" you discovered please?
      LyonsG_85618
      Jeff. The monitor we were using was a .jsp file. Using this via browser or via curl worked (i.e. you got the expected response). However the developers investigated issue and when the F5 monitor was seen on server it did not respond in the same way as a browser. I'll try and get more info next week. Graham
    • Ellison_Zhang_2's avatar
      Ellison_Zhang_2
      I met similar issue. What method does F5 use for HTTPS monitor? curl , telnet, GET or openssl (I am using F5 11.3.0).
