HTTPS application health monitor
Mohammed_M_Irfa
Hi folks,
Need your help to understand the HTTPS application health monitor,
How to capture the packets to view send and receive string?
In tcpdump, i can't see the send and receiving string if we enable the SSL parameters!
Is their any alter options to find the response from server?
Irfan
9 REPLIES 9
Lidev
MVP
MVP
Hi, use cURL command to see the server response :
curl -vk https://yourdomain.com/request
Mohammed_M_Irfa
Hi Lidev,
Thanks for instant response but i don't find the receiving string still:)
Can you show me your curl output ? you received an HTTP 200 OK ?
Mohammed_M_Irfa
[Active:Changes Pending] ~ # curl -vk https://x.x.x.x//index.html
*  Trying x.x.x.x...
* Connected to x.x.x.x (x.x.x.x) port 443 (#0)
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*  CAfile: /etc/pki/tls/certs/ca-bundle.crt
 CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Request CERT (13):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS alert, Server hello (2):
* error:14094410:SSL routines:SSL3_READ_BYTES:sslv3 alert handshake failure
* Closing connection 0
curl: (35) error:14094410:SSL routines:SSL3_READ_BYTES:sslv3 alert handshake failure
Ok, you have a handshake failure during the SSL Handshake.
Can you try curl -vk -3 https://x.x.x.x//index.html ?
Mohammed_M_Irfa
Getting same output, as previous:)
Disable SSLv3 protocol on your apache server and retry without -3 😉
https://disablessl3.com/apache.html
Mohammed_M_Irfa
Server is not under my control, So i can't do any think in server side.
I see, what version of cURL you use ? (curl --version), Support of SSLv3 was disabled by default in 7.39.
We'll try forcing TLS 1.2 : curl -vk ---tlsv1.2 https://x.x.x.x//index.html
