Technical Forum
Custom Alert Banner
HTTP monitor that goes to a single location instead of each pool member
Shurton
I'm want to create a reverse HTTP monitor that all goes to a single source instead of going to each pool member. Can this be done within the HTTP monitor template, or is there another way to do this, maybe through an iRule?
Any suggestions would be appreciated.
1 ACCEPTED SOLUTION
Create a new monitor of type HTTP, and set the "Alias Address" parameter to the unique address you want to monitor and also the "Alias Service Port" if you want to also force a specific port. Associate that monitor to your pool
2 REPLIES 2
  • I originally tried that with no luck, but after looking at it again, it works now. thx
