26-Nov-2020 05:17
Hi All,
i have pool member with port 80 and monitor i am using is http2 and another pool member with port 443 same http2 monitor am using.
port 443 pool member coming up and working fine.
port 80 pool member is not coming up and it shows down..
monitor used is
ltm monitor http2 MONI_STD_HTTP2_70.70.70.70_80 {
adaptive disabled
defaults-from http2
destination *:*
interval 5
ip-dscp 0
recv "HTTP_SERVICE_IS_ENABLED"
recv-disable HTTP_SERVICE_IS_DISABLED
send "GET /status/status.html HTTP/2\r\nHost: abcd.sooo.de\r\nConnection: Close\r\n\r\n"
time-until-up 16
timeout 16
can you update why its not working with port 80
14-Dec-2020
05:49
- last edited on
24-Mar-2022
01:22
by
li-migration
Hi ,
Can you try the below for your 80 port and see if you can get the expected response,
curl --http2 -kv http://ip/status/status.html
Similarly try it for 443 and see the difference. For more detail, refer this article.
