Technical Forum
How to see LTM stats when Flash gets decommissioned by 31st Dec 2020
Amresh008
As you may be aware that flash is getting decommissioned by 31st Dec 2020, how will we be able to see the dashboard data on LTM ?
Not sure whether AVR also uses flash, if it does, then what's the workaround for that ?
0 REPLIES 0
