26-May-2020 19:53
here is the output of show pool detail comment .
I have few questions:
show pool a p-sample.com detail
Gtm::Pool::A p-sample.com
Status
Availability : available
State : enabled
Reason : Available
Load Balancing
Preferred 104
Alternate 0
Fallback 0
Returned from DNS 0
Returned to DNS 0
Dropped 0
| Gtm::Pool Member: p-sample.com:A vs-DC1_samples-443:server1
| Status
| State : enabled
| Reason : Available
| Load Balancing
| Preferred 100
| Alternate 0
| Fallback 0
| Gtm::Virtual Server: vs-DC1_samples-443
| Status
| Availability : unknown
| State : enabled
| Reason :
| Destination : 192.16.1.2:443
| Link Name ---
| Global
| Picks 100
| Connections 0
| Virtual Server Score 0
| Throughput In Out
| Bits/sec 0 0
| Packets/sec 0 0
| Gtm::Pool Member: p-sample.com:A vs-DC2_samples-443:server2
| Status
| State : enabled
| Reason : Available
| Load Balancing
| Preferred 101
| Alternate 0
| Fallback 0
| Gtm::Virtual Server: vs-DC2_samples-443
| Status
| State : enabled
| Reason :
| Destination : 172.16.1.3:443
| Link Name ---
| Global
| Picks 101
| Connections 0
| Throughput In Out
| Bits/sec 0 0
| Packets/sec 0 0
27-May-2020 02:34
'Preferred' is referring to the preferred load balancing method used in the pool which the bigip tries first and the value (100) is how many times this method has been selected. Global 'Picks' value (100) is how many times that pool member has been selected.
Kind regards
Ben
