Technical Forum
How to protect Cryptojacking on F5
Rockers_319329
Recently i heard news that site can be effected by a Cryptojacking malware.
Can anyone tell me if F5 protect is type of malware? If yes is it activated automatically ? if not activated automatically then how it can be done in F5 big-IP.
Sorry if i asked a lot of question.
3 REPLIES 3
Rockers_319329
Anyone can help!
g-ram
Patch often, patch always. Check for XSS vulnerabilities in your site. If ASM is provisioned, check with F5 support or have parameter protection enabled (do with care as it requires a good understanding of the application). Validating of inputs is always a good idea. Check in the SIEM tools or IDS for monero miners.
https://hackerbits.com/programming/cryptojacking-javascript/
g-ram_31429
Cirrus
Cirrus
