PURI_337727's avatar
PURI_337727
Oct 27, 2017
How to overwrite iFileFile with iControlREST
I have uploaded files to F5 with iControlRest using "/mgmt/shared/file-transfer/uploads/" first and then "/mgmt/tm/sys/file/ifile" and now I want to overwrite them. The first method lets overwrite the file but the second one ("/mgmt/tm/sys/file/ifile") don't. I have tried with PUT but the response is "Operation is not supported on component /sys/file/ifile". Could you tell me how I can overwrite this?
  • Hello Puri,
    You can achieve this using the following command :
    To create the ifile use:
    curl -sk -u admin:admin -H "Content-Type: application/json" -X POST https://x.x.x.x/mgmt/tm/sys/file/ifile -d '{"name":"ifile_name","source-path":"file:/path/of/file"}'
    To update the ifile use:
    curl -sk -u admin:admin -H "Content-Type: application/json" -X PUT https://x.x.x.x/mgmt/tm/sys/file/ifile/ifile_name -d '{"source-path":"file:/path/of/newFile"}'
    Please let me know if it works for you.
    I've already tested in my lab.
    Waiting for your update.
    Regards
