How to hide the redirected URI path from users.
Venkata_Sandeep
In my current setup i have a below irule applied to virtualserver.
log local0. "host is: [HTTP::host], port is: [TCP::local_port]"
   if { [HTTP::host] equals "abc.example.com" and [TCP::local_port] == 443 } {
     HTTP::redirect "https://abc.example.com/abap/index.html"
As I'm using HTTP::redirect users are able to see the entire path(/abap/index.html) in the browser.
we just need to hide the redirected path(/abap/index.html) from the user.
can someone help me in writing it.
1 REPLY 1
Hello Venkata.
Try this:
when HTTP_REQUEST { log local0. "host is: [HTTP::host], port is: [TCP::local_port]" if { [HTTP::host] equals "abc.example.com" and [TCP::local_port] == 443 } { HTTP::uri abap/index.html } }
Regards,
Dario.
Regards,
Dario.
