Technical Forum
How to get plain text conditions and actions from each rule in policy?
HisMorty
I try rest api, but i get json not plain text, anybody know how to get plain text conditions and actions rules in policy how it look like in GUI. Tmsh gave json too. if anybody have idea, please write
2 REPLIES 2
Hello,
While you referring as "plain text" you mean ... ?
I'm asking because of the tmsh gives it as config lines as stored in bigip.conf file which is not JSON, it is "plain text".
tmsh list ltm policy Stop_Nimda
ltm policy StopNimda{
    controls { forwarding }
    description "This policy blocks the Nimda worm."
    last-modified 2016-03-02:11:46:00
    requires { http }
    rules {
        ClobberNimda {
            actions {
                0 {
                    forward
                    reset
            conditions {
                0 {
                    http-uri
                    query-string
                    values { root.exe admin.dll cmd.exe }
    status published
    strategy first-match
 If you need to remove "{" and "}" characters in the output, use same command with appending at the end of
  •  | sed -e 's,{\|},,g'
If you also need to get rid of those blank lines in the output, append below too
  •   | sed -e '/^ *$/d'
Hope this helps
i meant i need this plaintext. Cause text by tmsh not good readable
