Vshah's avatar
Vshah
Jun 02, 2023
How to extract applications historical data from F5 LTM
Hi All,
I am looking for historical connections utilization data of applications hosted on F5 LTM. Is there any way to check the same?
  • Hi Vshah ,
    If yiu have AVR module licensed on your box , you can collect everything related to specific virtual servers/ Applications.
    you will be having great visability on application urls , transactions , ips , Geolocations , which heavy urls that have and ...etc.
    Let me know if you have this module , I can guide you to use it properly.
    If you need to know about it and how to provision it in your box  , have a look at the below Article :
    https://clouddocs.f5.com/training/community/analytics/html/class1/modules/task1.html
    • Vshah's avatar
      Vshah
      Hi Mohamed_Ahmed_Kansoh,
      Thanks for your response. Yes I am using AVR module.
      Kindly guide me how can I get the data from that.
      • Hi Vshah
        you are welcome,
        AVR is a very useful module to collect huge amount of metrics and application statistics :
        First I will tell you the needed steps and will attach an article will help you in details :
        1- create a custom analytic profile , Local traffic >> profiles >> Analystics >> HTTP Analytics >> and
        hit create.
        2- Select in the profile all needed metrics that you want to collect and select the virtual server that you need to collect these metrics for.
        Note : you can add multiple virtual servers as you can , but please monitor your CPU and memory because AVR consumes little bit CPU , if you have a free in CPU and memory it would be great.
        3-  Hit Finish and wait almost 10 minutes , for changes to take effect and the bigip recieve a sufficient traffic.
        4- After that let's say 1 hour for example :
        Go to Statistics TAB >> Analytics >> HTTP >> Overview.
        you will see the magic ๐Ÿ˜„
        you can navegate all statistics also play with time slots and you can export a pdf report to review everything offline and extra ...
        Please Review this article for more details :
        https://clouddocs.f5.com/training/community/analytics/html/class1/modules/task2.html
        I hope this helps you ๐Ÿ™‚
