Technical Forum
How to disable iControl on LTM
tatsu
I want to know how to disable iControl (REST API) on LTM.
Because I don't use these function and iControl sometime has critical vulneabilities.
Regards,
2 REPLIES 2
Samir
MVP
MVP
As such there is no direct options to disable iControl (REST API) on LTM. However you can restrict userID or Source IP/subnet to access load balancer.
tatsu
Thank you for you reply.
I understood that there are no way to disable iControl.
I will try your advices.
Regards,
