SP's avatar
SP
Oct 31, 2019
How to configure "PEM GY interface"
i have been searching for how to configure "PEM GY interface" .i configured below in "profile of subscriber management"
pem profile diameter-endpoint Gy_endpoint {
  defaults-from diameter-endpoint
  destination-host none
  destination-realm OCS
  fatal-grace-time {
    time 500
  msg-max-retransmits 2
  msg-retransmit-delay 1500
  origin-host gy.bigip.f5.com
  origin-realm bigip.f5.com
  product-name BIG-IP
  supported-apps { Gy }
is the configuration correct? any other configuration required for " PEM GY interface"?Any suggestions are greatly appreciated.
  • what i see look pretty similar to the documentation:
    https://devcentral.f5.com/s/question/0D51T00006zuvHdSAI/how-to-configure-pem-gy-interface
    i assume something is not working or are you just double checking?
    • SP's avatar
      SP
      I want to know about Configuration needed for PEM GY configuration.The above commands i got in a document,not sure what are configuration needed for PEM GY to work .It will be great if you can help me
      • got no direct experience, might be wise to reach out to your local F5 team and see if a partner with experience in this can assist.
