Technical Forum
Custom Alert Banner
How to Configure a VIP where Backend is JDBC
Subrun
Hello,
Please help me with some guideline as per below requirement.
How to configure a VIP in F5 that will have an Oracle Server at the backend and that its JDBC. JDBC Backend Server will listen on a Custom Port like 2488.
Client will connect to the database using SSL/TCPS. That means VIP has to listen on 443 ? And with this type of setup to secure the connection from Client to F5 , I need to add SSL Cert. Is it possible for this type of JDBC VIP ?
If I want to create a VIP based on the above requirement ,
-- What type of VIP I should Create ? Standard , Performance Layer 4 ( if I use this will not be able to use Cert )
-- Which iApp I can use ?
-- What will be the monitor type ?
-- Will it be SSL Bridging or SSL Offload ?
-- If SSL Bridging Same Client to F5 Cert should be installed at Backend Server ?
1 REPLY 1
JRahm
Community Manager
Community Manager
I have not done that before, but it seems there is a solution in this Q&A thread.
