RomaineShultz's avatar
RomaineShultz
Jun 07, 2022
How to check which F5 BIG-IP product is installed
I want to check which BIG-IP product is installed at one of my VM. Is there any tmsh command for this? The following command does not return the complete system info. tmsh -q show Thanks
  • Hi,
    Check the /var/log/liveinstall.log  and strings like *** Live install end at 2022/xx/xx xx:xx:xx: succeeded ***
    Regards
