Technical Forum
how to check node uptime based on health monitor
Juanprad
i need to check the uptime of the node based in health monitor.
For example, one node have 03 health monitor associate and i need check the uptime for one specific health monitor.
Exists an a GUI option or cli command for check this.
1 REPLY 1
Paulius
MVP
MVP
@Juanprad I don't believe a way exists to send one command and receive the uptime of a pool member or node. The following command can be used to run through the logs and see the time difference of when a particular pool member went from down to up or up to down and then you can find the time difference between them using the log timestamp.
zegrep -i "monitor.*status" /var/log/ltm*
