Micros_88999
May 02, 2014Nimbostratus
How to auto yes to tmsh show command ?
Hello,
I would have one problem in tmsh. From bash I could check the configured virtual servers name :
From bash
echo yes | tmsh show ltm virtual | grep $ tmsh -q show ltm virtual | grep $
but the question is, how could I check it directly from tmsh ? My problem is that when I made a script it always wait for input yes, if it is possible I would use a correct command which doesn't wait for input.
show ltm virtual | grep $ Display all 630 items? (y/n)
At this moment to use bash would be problematic. Please let me know if you have any solution for this in tmsh.
Best Regards,
Csaba
