Yesh1923's avatar
Yesh1923
Mar 06, 2023
How to add two http_request irule in F5 ver 16.1.3.2
  • If you have one irule , you can use priorities  of each "when requests":
    when HTTP_REQUEST  priority 100 {
    when HTTP_REQUEST priority 200
    You can also have multiple irules attached to a virtual server.
    https://clouddocs.f5.com/api/irules/priority.html
    • Yesh1923's avatar
      Yesh1923
      team am getting below error with f5 version 16.x.x and not getting error with f5 version 13.x with using same irule ,can any support this issue , if i spoofing the am not facing the issue , if its going to public dns only we facing issue with f5 ver 16.x (same is working in f5 ver 13.x)
      <!DOCTYPE html>
      <!--[if lt IE 7]><html class="no-js lt-ie9 lt-ie8 lt-ie7" lang="en"> <![endif]-->
      <!--[if IE 7]><html class="no-js lt-ie9 lt-ie8" lang="en"> <![endif]-->
      <!--[if IE 8]><html class="no-js lt-ie9" lang="en"> <![endif]-->
      <!--[if gt IE 8]><!--> <html class="no-js" lang="en"> <!--<![endif]-->
      	<head runat="server">
      		<title>Page not found | Esaar</title>
              <meta name="viewport" content="width=device-width, initial-scale=
    • Yesh1923's avatar
      Yesh1923
      my requriement is to add multiple irule in one VS , this is what i used version 13.x and now upgraded to version 16.x but this mutiple irule does not support
      please help
