13-May-2022 10:31
I have a VS with multiple ssl certificates, however, we need to add around 500 Certificates to a single virtual server, I have searched but I do not find any information on whether there is a limit or performance impact when you add many SSL Certificates to a single VS, it does not matter? only the number of connections?
15-May-2022 05:01
Hi @Mario_Franco ,
There’s no as such limit defined for number of client-ssl profiles per vServer. But you should check SSL TPS (Txn per sec) for your F5 system and also need to consider the resources utilization.
Ref. articles-
