Technical Forum
How i check F5 only HTTPS for web management ?
AlearthieS
Cirrus
Cirrus
How i check F5 only HTTPS for web management ?, The customer concert about http
1 REPLY 1
iaine
MVP
MVP
Hi - you can use netstat to prove that http is not open on the management interface. This should work
netstat -an | grep <management_ip>
There's loads of info out there about securing your device if this is a concern. Some examples are...
https://support.f5.com/csp/article/K13092
https://support.f5.com/csp/article/K17333
https://support.f5.com/csp/article/K13309
