19-May-2020 21:17
create monitor https m-test-host.c-name.test.doamin.com-HTTPS-8090 interval 15 timeout 60 send "HEAD /test.html HTTP/1.1\r\nHost: test-host.test.doamin.com:8090\r\n\r\n" recv "HTTP/1.[01] [23][0-9][0-9]"
modify server server1
virtual-servers add { vs-dc1_test-host-8090 { destination 192.168.11.21:8090 } }
exit
exit
modify server server2
virtual-servers add { vs-dc2_test-host-8090 { destination 172.16.5.12:8090 } }
exit
exit
create pool a p-test-host.c-name.test.doamin.com
modify pool a p-test-host.c-name.test.doamin.com
members add { server1:vs-dc1_test-host-8090 { member-order 0 } }
members add { server2:vs-dc2_test-host-8090 { member-order 1 } }
monitor m-test-host.c-name.test.doamin.com-HTTPS-8090
load-balancing-mode global-availability
alternate-mode none
fallback-mode none
max-answers-returned 1
ttl 10
exit
exit
exit
create wideip a test-host.c-name.test.doamin.com { pools add { p-test-host.c-name.test.doamin.com } }
environment setting: a cname has been add:
I have a GTM configuration above , I am wondering how GTM https monitor works, here is my understandings, is that correct ?
test.host.c-name.test.domain.com
3. since the c-name.test.domain.com will be resolve by itself , GTM check the configuration , found that a pool is configured for
4, GTM check the pool member aliveness with command ,
curl --insecure -v https://192.168.11.21:8090/test.html
curl --insecure -v https://172.16.5.12:8090/test.html
if any of the pool member is up , the pool will be up , the wideip will be up.
20-May-2020 17:15
In general, BIG-IP doesn't do name resolution as part of the monitor process, instead using the IP addresses defined for pool members, so you may only see the Step 4 traffic.
20-May-2020 20:53
thank for your reply . if GTM doesn't request DNS resolution,what is the host in the monitor configuration used for ? thanks .
