johnbernardcheu's avatar
May 08, 2017
How does Virtual Location monitor determine if pool member is local?
Hi there, doc says that the virtual location monitor determines whether a pool member is local (residing in the same data center as the BIG-IP system) or remote (residing in a different data center). How does it do this? Thanks!
