How do I change my self signed device certificate and at the same time upgrade from 1024 to 2048 bits ?
S_Meulmeester
Altostratus
Altostratus
How do I change my self signed device certificate and at the same time upgrade from 1024 to 2048 bits ?. Using the Gui doesn't allow me to change the size to 2048
2 REPLIES 2
Shiraz
Altostratus
Altostratus
try looking at this thread.
https://devcentral.f5.com/questions/ssl-device-certficate-change-from-1024-to-2048-bit-length
However, I checked in version 11.5.3, its already 2048 bits
Stanislas_Piro2
Cumulonimbus
Cumulonimbus
you can use this command to create the new Certificate with key:
openssl req -x509 -nodes \ -days 3650 \ -newkey rsa:2048 \ -keyout /config/httpd/conf/ssl.key/server.key \ -out /config/httpd/conf/ssl.crt/server.crt \ -subj /C=FR/\ O=Company/\ CN=bigip1.f5demo.com/\ L=My\ City/\ ST=My\ State
Then restart httpd service:
bigstart restart httpd
