29-Jan-2021 07:26
Hi F5 community,
I am new to F5 and still learning the console. Few days ago I was asked to configure F5 to block all but few pages in a website. Our web link format is as follows:
http://example.company.com:7077/pls/apex/f?p=769:9:0::NO:3:N6_COUNTY
Static Portion always http://example.company.com:7077/pls/apex/f?p=
Application Number for example 769
A list of colon separated items
i. Application Page for example :9
ii. Application Parameters for example :0::NO:3:N6_COUNTY,P3_TYPE,P3_SORT:3,A,R
The requirement is to allow 6 applications(app numbers and everything to it's right in that URL) and block all requests. On F5, I am showing the URL as "/pls/apex/f" . I don't think I can achieve this by URL config. How can I get this working?
Thank you.
29-Jan-2021 13:38
Hi Sharath413,
if { not ([HTTP::uri] starts_with "/pls/apex/f?p=") } {
drop
If you want to check entire uri, you can use regex.
https://clouddocs.f5.com/api/irules/matches_regex.html
01-Feb-2021
11:56
- last edited on
24-Mar-2022
02:13
by
li-migration
Thank you so much for your comment. It is really helpful but I'm new to iRules and so wondering if I can do the same with ASM security profile instead?
Please advise.
19-Feb-2021 22:59
You need to do next:
1) Create all allowed URLs on "Security ›› Application Security : URLs : Allowed URLs : Allowed HTTP URLs" page
2) Remove pure wildcard (*) URL (if exists)
3) Enable Alarm and Block for "Illegal URL" violation
Thanks, Ivan
