Technical Forum
helpe for Irule
Mahdi_Moradi
Hello I have a ticketing server that works with the following ports When I add this server in the load balancer After I enter the username and password, the page remains in loading mode.
ip: 30112 web
ip :30110 Athuentication
ip :30111 sevice
4 REPLIES 4
Paulius
MVP
MVP
@Mahdi_Moradi Without seeing more of your configuration it makes it a bit difficult to help with the solution. If you only had one server in rotation before and you are adding this new one as a redundant host I would guess that you have an issue with persistence or persistence across services. I would ensure persistence across services is enabled and see if that resolves your issue.
persistence none
pool config  :  1 node , ip adddress  port : all port
vs : dast add  , port :30112  -- auto nat -- porofile http -
config is default
The login page opens But after logging in, the page is in loading mode and does not log in The service is a ticketing portal that works on port 30112 after logging in
     30112
app   30110
service 30111
@Mahdi_Moradi Do you have a different virtual server per destination port?
