HarshadS's avatar
HarshadS
Sep 14, 2021
Solved
help with irule string match
How can I parse an HTTP URL to then send https://www.example.com/foo/index.html to pool A and https://www.example.com/bar/index.html to pool B?
Basically I need to parse the first part of the HTTP::uri (/foo/ and /bar/) and switch based on that.
Can someone point me to some documentation or help me in how I can get this to work?
  • when HTTP_REQUEST {
    switch -glob [HTTP::uri] {
    "/foo/*" { pool poolA }
    "/bar/*" { pool poolB }
    default { pool pool_default }
  • xuwen's avatar
    xuwen
