22-Sep-2020 15:21
Hello, I'm looking for help with an irule that will bypass the client authentication certificate for a group of ip addresses. Currently we have the client cert auth working with a client ssl profile in LTM set to require client authentication. We would like to allow certain IP addresses access to the site without client certificates.
I assume that I would need to change the ssl profile to 'request' client auth and create an irule to handle things from there. I think the logic should be something to the affect:
if ip is in data group list of IP addresses->allow access without cert
request client certificate->if valid cert presented->allow access
If no cert and not on list->deny access
Any help would be appreciated.
16-Oct-2020 12:47
Thank you for the response. Your answer helped me end up with the below. The key was that the ssl profile assigned to the VS had to be set to ignore.
if {[HTTP::uri] starts_with "/uri1" || [HTTP::uri] starts_with "/uri2"} {
if {not [matchclass [IP::remote_addr] equals NOCERT_IP_LIST]} {
SSL::session invalidate
SSL::authenticate always
SSL::authenticate depth 9
SSL::cert mode require
set cmd "SSL::profile /Common/require_clientssl"
eval $cmd
SSL::renegotiate
event disable all
