Technical Forum
Custom Alert Banner
Help tweaking my iRule
jlb4350
Cirrus
Cirrus
Hello all. I have an oubound virtual server that allows all traffic and protocols to any address, it's a wildcard outbound. I'm wanting to use an iRule to block outbound connections to Russia using data referenced in a data group. I created the following data group and iRule, but it ended up blocking everything when I attached it to my wildcard outbound VS. Are there any iRule gurus could can help me tweak this? Any help is much appreciated!
Data group:
iRule:
1 ACCEPTED SOLUTION
The iRule is slightly wrong in that it is trying to pull out a value of RU and then matching the IP address to the value which would never happen.  I would use the framework set in the support article and do something like this:
when SERVER_CONNECTED {
    set ipaddr [IP::remote_addr]
    set fromCountry [whereis $ipaddr country]
    if { [class match $fromCountry equals GeoIPOutboundBlockRussia] } {
         log local0. "Attacker IP [IP::client_addr]"  ;#  This can be removed/commented out if not required
         drop
6 REPLIES 6
David_Larsen
F5 Employee
F5 Employee
You are running into a formatting issue with your datagroup.  The datagroup String should be RU and no value necessary.  This is a good reference: https://support.f5.com/csp/article/K43383890
Interesting. So I should just put RU in the string field and nothing in the value field, and that will be my string record, like this:
How about the iRule, does that part look alright?
Thank you for your reply and help!
         drop
jlb4350
Cirrus
Cirrus
Perfect, I'll give that a try and see what happens tonight. I'll report back, thank you again for your help!
did it work? just curious
jlb4350
Cirrus
Cirrus
Sorry for the late reply, I've been traveling.
I ended up piecing together a few iRules that I found to come up with this and it works perfectly. I may tweak it in the future, but this is working. It involves the countries to block access to in a data group and the iRule to reference that group:
